I want actual examples showcasing the usage of each model and each and every variation of parameter
I am inside Topaz AI video:
I see all these models and parameters, and see things like “++ this parameters is better for usecase 1”, “do a small value of this option for usecase 2”, etc… all over the UI.
I would prefer to see at least some example with “input videos” of different styles and expected outputs,
for example have like 5 videos with different aesthetics: “realistic, anime, old, low detail, low frames” , then show for each a “tutorial” what parameters should be used an what to expect. Then the user shall try them all and “learn” what are best parameters for each use case.
But I would like it to be also extensive, I would like to see usage of all sorts of parameters (for example the “focus fix” which until now I am not sure when it can be interesting to use, but I am sure it can be), not just 5 uses cases.
