I need help with upscaling images made in Midjourney
Hi everyone, I have been using Gigapixel AI since February, and I’m still useless at upscaling many images made in Midjourney, especially oil paintings.
Is there anyone out there who feels like giving me a hand with tweaks to get what I need?
I’m giving up on images because I just can’t get them to upscale to 24x36" without being incredibly bad, when maybe I could actually use them. (I have an Etsy shop and sell digital images so they have to be perfect).
Thanks in advance for anyone who might help :slight_smile:
Sophie
Please provide an image so that we can give it a try. You can not scale it up to a certain Inch size because your digital image has no size. It has only pixels :slight_smile:
OK, I’ve uploaded an example of an oil painting style image from Midjourney and a watercolor; for photography generated by Midjourney I can upscale them by 4.02 to get to the 10800x7200 pixels I need, but these are just beyond me!
Especially with the watercolor, I need a way to soften the image first I think.
google drive
It could just be that I need to learn how to prompt differently in such a way that the images generated are easier to upscale?
Anyway, thank in advance for any and all help!
Sophie
Yes, I see the problem. it often looks way too oversharpened. How about the Standard model 4x and Sharpen, Denoise, Fix compression to the lowest setting?
Thanks, it’s not bad but I couldn’t sell an image that looks like this at 100%. It’s better than how I got it though!
I think I need something that softens…!
Or someone to tell me what kind of oil painting prompt I should be using in Midjourney to get something upscalable…
