I downloaded Topaz Photo Ai and it runs so slow I can really not use it anymore
Downloaded Topaz Photo Ai and it runs so slow it is not
usable on my MacBook Pro.
Intel MacBook with integrated Intel graphics?
If yes then I fear there’s not much anyone can do.
For TPAI to sufficiently work you need at least a separate GPU or better an Apple Silicon based device.
Topaz Labs Download Page
If you are still experiencing problems please reach out to us at the following link:
Topaz Labs | Support Page
