I have had great success and results with the Hyperion HDR model in Topaz Video 1.7.0, I have yet to get Hyperion 2 to successfully complete. I have attached log files, but in summary after running for 6 days attempting to apply this HDR model to a 4K movie, it reset my PC. This model typically takes days and has never completed. I have a high end Nvidia RTX 4090 graphics card so I don’t think the GPU is the issue. Any suggestions based on the logs?
No overclocking. It is not running hot. It does not shut down. It reboots. I would think it would take less than 6 days for it to shut down due to overclocking or rebooting.
I have similar issues but using other models, like SLP or SLM. I’m pretty sure it’s not my GPU, because the rendering runs for days without problems. But then, when it’s nearly finished, or usually during the last 25% of the video, my PC suddenly reboots.
This never happens during the first 50% of a video, and it only seems to happen when the rendering already runs several days. So there must be something else causing it, maybe the cache is getting too large or something similar. (it was not out of disk space)
I just wanted to mention this so that the focus doesn’t fall solely on Hyperion. Maybe others have observed similar issues as well, and if so, we might be able to narrow down the cause.
That report has multiple entries for Windows Update store-agent event failure and one for Intel’s Extreme Tuning Utility tool. Check to see if you have any Windows updates that need to run and complete, also check if that Tuning Utility app is running or has changed any of your GPU and system controls.
When our app is running hard, it can quickly peak and cause a reboot or crash if the system’s settings are tweaked beyond default values. This is why we dont recommend overclocking in most cases.
Also, open Event Viewer > Windows Logs > System. Filter for Event ID 41 (Kernel-Power, meaning the PC lost power/rebooted without a clean shutdown), Event ID 6008, and any WHEA-Logger errors around the timestamp of a Topaz crash. That might give some more information on what caused the reboot.
