Hi everyone, I’m trying to figure out how to use the Starlight Precise model while also adding frame interpolation to the export queue. Does anyone have a workflow or tips for getting both of these features to work together?
The Starlight models are not able to be combined with other models or processes at this time. To apply frame interpolation, you will need to run a second process.
its okay, i see there’s a option reimport, will there be a queue task feature. it can queue task.
You can currently submit multiple videos to the export queue and have them run, however, if you are exporting a video with Starlight Precise and reimporting it, you will not be able to queue that up until it has completed and is brought back into the app.
