How to save a preset?
Processing is slow and it’s repeated after each slider move. When I set one photo correctly I would like to use same settings for next photos probably… how to do it? I don’t see option to save a preset, I was only able to find default face value in preferences.
On the thumb nails below are three dots. There you can apply the settings to all images!
