Hi,
I’ve got several presets I’ve saved and no longer use. Is there a way to delete them to unclutter the dropdown menu?
Thanks!
Mark
Hi,
Thanks!
Mark
Just select the preset you want to delete and then click on the trash can icon just to the right of the preset drop down box.
Perfect! I knew it had to be staring me in the face!
Mark
