This isn’t a Topaz issue so it’s in general and I figured maybe people here would know what’s going on. I take shots and edit them in Lightroom 6, and export them. Sometimes I they show up with extra noise in when viewed.
This plays into Topaz tools as I just had lousy results and when I looked at original that is in the program versus what I normally see when I few it, it’s super noisy!
This is how they are appear usually.
This is how they show up with more noise. I know this is IrfanView, I’m only showing it with that because I trigger the bad version at will. (Open the image and then resize the windows -not the image, when I let go of the cursor the image will clear up again)
I put in three test images form the same night and the results were great with little artifacts or issues. I dump in the rest but first few I look at load like the second and more noisy example which obviously is going to have a worse turnout. I have noticed a few times that uploading to services it may happen too that the nosier image will show up.
I export as JPG, 80% and sRGB color space.
