Help. Topaz Impressions 2 saves black frames only after I installed Studio 2 (which does not include Georgia O’keeffe simulation that I want to use). I re-installed but same result.
Any ideas?
Please go to Help-> Graphics info in Topaz Studio 2, press Copy and post the info here. Also if you have Dual GPUs on your system make sure you are using the High Performance GPU which will be either a AMD or NVIDIA.
Instructions for configuring you applications are here:
https://support.topazlabs.com/hc/en-us/articles/213614538-Using-Switchable-Graphics-with-Topaz-Labs
thanks for responding
Application & Version: Topaz Studio 2 Version 2.0.12
Graphics Hardware: Intel(R) HD Graphics P630
NVidia Quadro M2200
OpenGL Driver: 3.3.0 - Build 23.20.16.4973
CPU RAM: 32574 MB
Video RAM: 1500 MB Total, 1200 MB In Use
Preview Limit: 3466 Pixels
Thank you.
That has fixed the problem.
I cannot believe they shipped me a workstation with a quadro graphic card and did not enable it.
Cheers
Ray
