I’m new to Mask AI, Can anyone help when it comes to masking Trees. I need to remove the back-ground completely from between the branches. Is there an easier way of doing this without having to use the “Contrast” brush and try to get between all the leaves and branches.
This is the best technique, works in full Photoshop as well.
The mask isolates the trees. You do not have to add the sky!
Hi Jack, thanks for your reply, the problem I have is the “dark sky” that is showing through all the branches. If I apply a new background the old one is still showing through the branches?
Ps Sorry Jack, I should have said I’m using Paint Shop Pro 2020 64 bit.
