Hi, I’d like to know if you can help me.
I have a lot of videos recorded from my early days when film cameras like my Canon EOS3 were still used.
I’ve been a concert photographer for many years and used a Fujifilm FinePix S9500 for my first digital photos in conjunction with my Canon which was much better.
I bought this camera because it recorded video, but it was a very very modest video.
I have some real gems recorded that I’d like to scale up to at least 1080.
I’ve managed to get some pretty decent stuff with some tests. Considering its resolution was 320 x 240.
I’m not sure which model to get the best quality possible with… the files were pretty mediocre because they were very compressed in AVI format.
And it has some strange vertical lines when you try to view it in full screen.
I’m leaving you a file, I want to recover each video, stabilize and color grade it, give it a new life.
I want to master the audios with the software: ozone 9
but first I want to scale at least up to 1080p, I know it’s a huge amount of upscaling, but the concerts and videos are worth a lot for their content, I want to at least try.
The sample I leave you was recorded 22-01-2009 THE SMITHEREENS
Download
This link will expire on 23/10/2024 at 21:42
info:
General
Complete name : C:\Users\infoc\Desktop\DSCF6313.AVI
Format : AVI
Format/Info : Audio Video Interleave
Format settings : BitmapInfoHeader / PcmWaveformat
File size : 230 MiB
Duration : 6 min 46 s
Overall bit rate : 4 747 kb/s
Frame rate : 30.000 FPS
Video
Format : JPEG
Codec ID : MJPG
Bit rate : 4 613 kb/s
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.002
Stream size : 223 MiB (97%)
Title : FUJIFILM AVI STREAM 0100
Audio
Format : PCM
Format settings : Unsigned
Codec ID : 1
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 1 channel
Sampling rate : 16.0 kHz
Bit depth : 8 bits
Stream size : 6.20 MiB (3%)
Alignment : Aligned on interleaves
Interleave, duration : 1000 ms (30.00 video frames)
Interleave, preload duratio : 1000 ms
