Having issues
I often have to load AI twice as it crashes on the first try.
After going through load and autopilot settings when I click on save it often just sits there for hours and does nothing, no movement on the progress bar, it’s not frozen as I can still access the menu.
Using Topaz AI 2.0.3, Windows 11
please write to support@topazlabs.com :slight_smile:
@trevor.baker-6928 Yes, please submit a ticket and we’ll be able to help you troubleshoot with specific info about your computer.
Thank you Tim, DxDiag.txt has been sent to you
