The new version 4.0.5 has at two severe issues. If you put a video clip in, and do nothing but artemis, when it shows how fast it is processing it does not show the FPS correctly. Also if you now compress a H264 to H265 the audio is out of synch. I am not the only person experiencing this. When does Topaz plan on releasing 4.0.6 to fix this? I can’t use Topaz video enhance anymore as it kills my audio synch upon play back. H264 works, it can still create clips that do not have something wrong with them and players can play those clips without severe audio synch issues.
Help!
I have the same issue Bug - Innaccurate FPS Export - #2 by NerdyPhotos
Added the audio sync issue here - Bug - Audio Sync Issues
