H.264 to .MOV ProRes Std Frames Loss Issue in Topaz Video 5.0.2
Hello and I hope you’re all well and thriving.
Before posting, I searched the forum for similar issues using the terms “H.264 to ProRes” but was unable to find any discussions addressing the specific problem I am facing.
I’m experiencing an issue with Topaz Video Version 5.0.2 where imported MPEG (H.264) videos are exported as .MOV ProRes 442 Std with fewer frames. Specifically, I imported two 4-second videos at 24FPS and the first video ended up missing 7 frames, while the second video was short by 3 frames.
Please find all relevant information below and provide me with a possible explanation and a solution.
I am also attaching:
a. SystemReportForTopazSupport.spx
SystemReportiMac.spx (8.2 MB)
b. logsForSupport.zip
logsForSupport.zip (168.5 KB)
Many thanks in advance for your prompt reply and solution!
Best regards,
Takis
INFO
1st Video File Import:
Type: MPEG Movie
Video Codec Type: MP4, H.264
File Size: 2,58 MB
Image Size: 1408 x 768
Frame Rate: 24,00
Total Duration: 00:00:04:00
Pixel Aspect Ratio: 1,0
Alpha: None
Color Space: Rec. 709
My Topaz Video Settings
Video Settings:
Input: 1408 x 768 @ 24 PFS
Output: 3840 x 2160 @ 24 FPS
Crop setting: Crop to fill
Frame rate: 24 FPS (Original)
Enhancement:
Video Type: Progressive
AI model: Proteus - Enhance MQ
Parameters: Auto
Add noise: 0
Recover detail: 0
Focus fix: Off
Frame interpolation: On
Slow Motion: None
AI Model: Apollo
Duplicate Frames: Replace (selected)
Sensibility: 10
Export Settings:
Output type: Video
Codec: ProRes
Profile: 422 Std
Audio mode: none
Container: mov
Topaz Video AI exports the file as:
Type: QuickTime Movie
File Size: 198,41 MB
Image Size: 3840 x 2160
Frame Rate: 24,00
Total Duration: 00:00:03:17
Alpha: None
NOTE: when I right-click the file in my bin in Premiere and then click on „Media File Properties“, I see the following information:
Video: There are 89 frames with a duration of 41/1000ths.
Video track 1: Duration is 0:00:00:07 (I do not understand what Premiere wants to say with this info)
Average frame rate is 24,01 fps (I also do not undersand why “average” FPS and why 24,01fps)
Video track 1 contains 1 type(s) of video data:
Video data block #1:
Frame Size = 3840 x 2160
Compressor = Lavc60.37.100 prores_videotoolb
Quality = Normal (3,00)
Temporal = Normal (3,00)
Issue: the input 24FPS MP4, H.264 file is 4 seconds long, whereas the output of the 24FPS .MOV Apple ProRes 422 Std file that Topaz Video exports is 3 seconds and 17 frames long - with 7 frames missing.
2nd Video File Import:
Type: MPEG Movie
File Size: 2,58 MB
Frame Rate: 24,00
Alpha: None
My Topaz Video Settings: the same as with the 1st Video conversion above.
File Size: 221,71 MB
Frame Rate: 24,00
Total Duration: 00:00:03:21
Alpha: None
NOTE: again, when I right-click the file in my bin in Premiere and then click on „Media File Properties“, I see the following information:
Video: There are 93 frames with a duration of 41/1000ths.
Video track 1: Duration is 0:00:00:07 (I do not understand what Premiere wants to say with this)
Average frame rate is 24,00 fps (the “average” FPS here is 24, where for the first file above was 24,01)
Issue: The input 24FPS MP4, H.264 file is 4 seconds long, whereas the output of the 24FPS .MOV Apple ProRes 422 Std file that Topaz Video exports is 3 seconds and 21 frames long - with 3 frames missing.
