Guidance | Generative Model Seeds
When using recover model the small preview gives a better result then the full preview and export.
Small Preview
Full Preview
I seem to always get the same seed (same exact result) whenever I try regenerating a preview with either of the generative models. Closing and reopening the program doesn’t fix this.
Sometimes with Recover if I only select a small portion of the image rather than regenerating the whole thing, it’ll use a new seed, but when I go to export, or I try to regenerate the whole image, it’ll still use the old seed.
In fact, with regenerate entire image, it’ll get halfway done generating, and then skip to the end and always say it took about the same amount of time, as if it’s copping out and pulling the result from a cache. I don’t know if that’s what it’s doing or if it’s just fast at rendering, but either way the generated image never changes!
It’s good that seeds are saved from preview to export, but I can’t regenerate if I don’t like a result!
Please fix this!
I have the same issue. I would expect that an upscaler that I pay for would at least have random seeds the way an open source model such as Flux would. In fact, I am considering using Flux/Comfy UI for upscaling now due to this limitation.
Hello!
As of writing this (current: v8.3.4), the expectation for seed generations is that there will be differences between cropped previews, local export, and cloud render.
This applies to Recover and Redefine.
For example, the preview sizes of Small, Medium, and Large all provide the models with different sampled areas of the image, and the processing of those areas will generate different results than a preview or render of the entire image.
