Guidance | Applying Face Recovery
Hello I’ve just today updated to Gigapixel 8.3.4 and straight away noticed this.
I always use the Select Faces to Recover button to confirm that the face / s have been correctly selected but with this version the Apply button is greyed out and the only way to un-grey it is to deselect the face and then straight away press the Select Faces to Recover button and then select the face and then Apply button is un-greyed.
I include six screen captures to visually show what I mean.
It never worked like this before!
Similarly. Seven faces and the Apply button is greyed out. Deselect the gentleman in the suit and the Apply button is usable again. Straight away Select Faces to Recover and add the man in the suit and then the Apply button is then available.
I was using Gigapixel 8.3.0 yesterday and it wasn’t behaving in this way. It’s always been my routine to check faces have been selected and Applied correctly by checking even while Gigapixel is still working.
Hello!
High confidence faces are automatically selected when Face Recovery is enabled, visualized by the blue outline.
When clicking “Select faces to recover,” the Apply button only activates when a change has been made.
If you click “Select faces to recover” and the face you wanted selected is already selected with the blue outline, there is no change to apply, so the Cancel button can be clicked.
Hello Tyler. It would seem that the Gigapixel v8.4.1 has sorted the problem.
I’ve gone back to v8.3.1 now for other reasons. v8.3.1 As I thought doesn’t have that problem.
Regards. :grinning_face:
