Group processing
I got 5000 pictures from an event (stage photography) Bharatham (dance). I’m trying to use the noise and upscale option and came to a setting that works well but I’m not able to copy the same setting to all 5000 pictures.
Step 1: Edit pictures via “Topaz AI.exe”
Step 2: Open Topaz AI and update one picture
Step 3: Missing the ability to copy the setting and apply to all other pictures. Upscale is in original picture, if i apply the setting to rest upscale is not taken into consideration.
Step 4: Every time I zoom in or out the processing happens again (preview updating) and it takes a lot of time for me to view the same picture in multiple zooms. Costly - sitting hours
How do i do bulk batch processing with Topaz with the setting I wanted?
Upscale was set to 2X but the processed images doesnt have upscale
