Grid Pattern on sky with Upscale and/or Remove Noise
Steps to reproduce issue:
Open .cr2 from EOS 70D. Apply Upscale and/or Remove noise and a grid pattern appears in sky background. Did not occur in 2.0.3.
Topaz Photo AI v2.0.4 on Mac
Are you using an Apple M1 or M2 device? We narrowed this issue down to the Upscale - High Fidelity model for these processors.
We reached out to Apple to see if they can fix this.
For now, I would recommend using the Standard model which shouldn’t have the grid issue.
I’m using an M2 Mac mini (2023) running Sonoma 14.0
Thanks!
Having the same issue
