Grid lines visible on images
I can see a checkerboard grid pattern on some of my images in Topaz Photo AI v2.3.1. The grid appears in the sharpening process. It appears only when using “standard” or “strong” sharpening - “lens blur” and “motion blur” do not produce the grid. The grid appears when using Nikon RAW NEF files, TIFs, and JPGs, but only on certain photos. The grid appears whether other tools are used with sharpening such as removing noise or if sharpening is used alone.
  1. The original image file.
  2. The processed image.
Dropbox File Request
