Then its something wrong in your pc or you use Windows on default settings and you have very high usage ram. In my modded config, games and programs use pagefile 100MB to max 1024MB. (I use manual 4096MB-4096MB for 16GB Ram.).
Windows in modded settings use page file when 90% ram its use.
Windows in deflaut settings use page file when 75% ram its use.
Aside of the Windows swap file, Iāve always been curious how the amount of RAM used by Photoshop and plug-ins is distributed. E.g., if I dedicate 75% RAM to Photoshop, will the plug-ins that I run within Photoshop (including Topaz) use the remaining 25% or a part of the 75% dedicated to Photoshop?..
There are 7 apps left that are open at the same time.
Adobe bridge alone is filling 12 GB of ram.
I would also say, for working people, 8 GB of Video Memory is Minimum and 32 GB of Ram is Minimum. 8 Cores + SMT is also minimum if you want to work fluid without stutter and thats Photoediting, culling and management alone.
Do you want just some new version or a good working version? I personally do not need the former at all but am ready to wait a year, if needed, for the latter.
Hi coming from VEAI, first time posting here for gigapixel ! two questions, there is no ādefaultā feature in gigapixel, is there a way to have the zoom to fit by default all the time ? same question with the save setting, i always use the custom name, but itās always the other one !
Thanks ! maybe editing a setting file or something ?
In Preferences - under the File menu - you can set a default prefix or suffix or both. Is that what youāre asking?
I am not aware of a feature to Fit as a default but there is a product features wishlist (separate from here) discussion board (check option under Products at top of page) where you can suggest & others can vote for that if theyād like it too. It seems it too would be a Prefs setting.
Hi! There isnāt a way to set fit to screen as your default but the keyboard shortcut should be Ctrl + 0 or Cmd + 0.
We have the same option in Gigapixel AI as Video Enhance AI to submit a feature request through the Help menu as well if you want to use that
I know the shortcut, but iām hand disabled, after a while it start to hurt when doing batch rendering ;). iāll sure use the feature request IMMEDIATLY lol ! (yes itās annoying in VEAI too ahah)
i put a suffix in the Preference menu, but each time I render (in batch) pictures , a menu ask me which name i want and itās the āautoā which is set by default.
itās seems itās happening only when doing batch processing.
if processing one picture only , the suffix set by default in preferences is used !
for the zoom by default, iāll try the feature request ;). thanks !
Sounds like something you may want to rpt to Tech Spt & open a spt request for.
This is a user - user forum. Meaning, itās a good 1st step to see if other users can help but if thereās a tech issue (either with your system specifically or a design issue) we (probably) canāt resolve it for you in most instances.
They may prompt you when you open the spt ticket, but be prepared to provide all the specs on your system and if you have any snips of what happens as visual backup to the written explanation youāll provide it will likely go a good way to helping ID your issue faster.
hey thanks for your help but iām in the Beta since one year and a half for VEAI, so I know pretty well how this Forum work lol. I was just coming here to see if it was a bug or an issue on my side.
No need to explain me how the forum work or what to do ;-).
I got Gigapixel many months ago, but just had the portunity to use it now and noticed this. Anyway, iāll see with the Devs or the support if itās a bug or an issue with my installion. Thanks anyway.
AI Processor canāt use my gtx1060
i selected to use gpu but still use my veryold cpu
GPU is 0% usage (3D, encoder, decoder, vram around ~100mb)
driver are updated to latest version
how to fix that???
