Gigapixel Upgrade Problems
Batch processing in 4.50 for Windows only works on the first file in my case. An extra dialog is added when you click Start processing for Batch parameters. Settings are not saved from run time to run time.
Not so as it does work fine for me on Win 10/nVIDIA GTX1050.
Make sure you are not using GreyScale images as input.
For clarification purposes please go to Help-> Graphics info, press Copy and paste the information here.
Thanks for your reply. My images are not GreyScale. Here is the info you requested:
Application & Version: Topaz Gigapixel AI Version 4.5.0
Graphics Hardware: GeForce GTX 1080/PCIe/SSE2
OpenGL Driver: 3.3.0 NVIDIA 445.75
CPU RAM: 16319 MB
Video RAM: 8192 MB
Preview Limit: 8000 Pixels
I added four jpg images to the program. All the pics should have been resized to a height of 1440 pixels. The first one was. The others were 1019, 1437, and 459 pixels respectively even though the program said they were resized correctly. Previous versions worked fine. I don’t think it’s anything I’m doing wrong.
Screenshot
