Got a free key with my A770 but before i activate it i wanted to try it first. The upscaled images are all blurry and unusable however as seen in the screen below.
You need to show the settings that you are using on the settings panel.
Turns out it was the OpenVino option, which is weird considering im using a A770. Now the start processing button is not working tho. When i click on it nothing happens.
