has how to create a shortcut key, to export images directly in lightroom using Gigapixel.
Because every time you have to click with the opposite mouse button and click on edit and on the program.
Is there a possibility to create a shortcut key?
Thanks.
Check in the Lightroom user guide.
Note that your reply was inappropriate and, as such has been deleted. You need to be polite on this forum.
See the reply above as Lightroom is the controlling application.
