Hello
I am a newcomer but here is my question.
I used Gigapixel AI on “Auto mode” to multiply by 4 my image.
The “supress noise” and “remove blur” section were also on “Auto mode”.
Once I exported my image on my desk, I then used Sharpen AI (using it on “Auto mode” too) to see the result. It showed on the split screen the original pic (treated on Gigapixel before) as “blurred” compared to the right side much sharper!
My question is:
How come, after using Gigapixel AI getting the pic sharper it still showed it “blurred” on the left (original) Sharpen AI software? Puzzling
Thank you for your answer
Kind Regards
Alain
