Gigapixel 8 keeps crashing with Redefine
It had been working for a while, I was able to export a couple of images with the 4x option and it went pretty well. After the sixth picture, it just starts crashing when I even try to generate a preview.
Topaz Photo AI 8 on MacBook Air M2
I also have this issue on a Macbook Air M1 which meets the minimum specs. Progress bar on the preview progresses to around 50-60% then crashes, even if I set the scaling to 1x
Anybody find a solution to this? Happens with every photo. I’ve tried on two different machines, including MacBook Pro with M3, plenty of Ram. Tried on a photo with a resolution of 799 × 533, certainly no monumental task. Crashes every time.
