Gigapixel 7.3.1 is Zero Bytes
Installed 7.3.1, the plugin is an empty file.
Are you looking to install Gigapixel as a plugin for Lightroom Classic or Photoshop 2024?
If this is relating to Photoshop, this is the expected file structure and you should gave additional plugin files for Gigapixel.
If you open Photoshop, upload an image, and navigate to the File > Automate dropdown menu, are you able to export the image to Gigapixel successfully?
Photoshop. Yes, I have the other 3 .plugin files. Thanks, just worried something was broken!
