Getting " Error Running Model" in craw batch 3.3.3
All i did is adding sharpening, then Adjust Lighting, then Balance Color on one photo, then saved as a preset, then applied to all.
When i Export 390 images, it only completes the first image, then gives errors to the rest one by one. I tried restarting my PC but still does the same.
If its a knows 3.3.3 bug, then how do i downgrade to earlier stable version?
I tried selecting in general instead of auto my RTX4090, but it didn’t help.
Just tried same settings on the JPG versions of the raw files. Still same error. Sometimes it processes 3 images ok, then i start getting errors. Now i’m trying to do the same on my slow M1 mac mini. Maybe only the windows version has the bug…
Nope, same errors there as well.
Looks like the software having issues with Batch processing, but processing 1 file at a time will take me forever… Its impossible to process 390 files one by one.
Any suggestions?
Thanx in advance.
Ok, i finally found an older Topaz Photo AI version 3.3.0 and now its working fine on my PC desktop.
One difference i noticed, it doesn’t add Denoise by default to each raw. On the version 3.3.3 the denoise was added automatically without an option to remove it for each craw file and i could only change its settings.
Now on version 3.3.0 i manually added the denoise and the rest of the enhancements exactly like before with the same settings and no issue this time around.
Please fix the batch processing bug on version 3.3.3
Thanx a lot!
