Getting constant errors
Intel 13900k
Nvidia 4070ti
Over half videos will not finish
Very unlikely to apply to your situation, but I’ve confirmed that TVAI 406 will error out if your system loses internet access, even for a few seconds, during processing. I live in a region of unstable web access, so this affects me.
Any chance you’re losing access intermittently?
It could very well be. I’m connected to to T-mobile’s home 5g internet. I’ve seen before that
my connection has been reset in the event viewer before… thanks
I have the exact same problem, and unstable wifi that is not going to be fixed anytime soon since it’s out of my control.
Presumably all the models have been downloaded and feedback has been opted out of. It shouldn’t need anything online.
I’ve taken to splitting hour long videos into multiple segments, then copying the ffmpeg command for each portion to a separate file.
Then I rerun the pieces that fail and hope that a rerun on that specific section will work.
Then check each piece individually again, repeat re-runs on additional failures until I get all of the pieces functional.
When I finally have all the pieces working correctly, I then have to splice it all together in another program…
What can be done about this?
And WHY does it break with wifi reconnect, what is it even doing that relies on the internet?
Hello everyone,
Our engineering team is currently investigating this issue. If possible, could any affected users in this thread email log files to help@topazlabs.com?
Please submit logs with the subject line: “ERR: processing interrupted by network change”
To gather logs, please select Help > Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the “logsForSupport” file to your reply.
Thank you!
One thing I did was to untick “anonymous data collection”. I’ve ran a few and it hasn’t had an error
