Fresh install of 2.2.1 broken with Entry Point Not Found error
Steps to reproduce issue:
Open app
Load photo.
Error “The procedure entry point zeDriverGetExtensionFunctionAddress could not be located in the dynamic link library C:\Program Files\Topaz Labs LLC\Topaz Photo AI\npu_level_zero_backend.dll” appears
I’m experiencing the same issue. I’ve already reinstalled Topaz Photo AI, run DISM CheckHealth and System File Checker, and attempted to re-register the .dll file.
