Frame interpolation
Why fps are locked in the menu ?
  • 23.976
  • 24
  • 25
  • 29.97
  • 50
  • 59.94
  • 60
  • 90
  • 120
Why isn’t there a simple “Custom” option allowing you to multiply the original fps by 2 or 3 (by doing the calculation yourself)
The choices proposed having for source of 23.976 necessarily result in a perception of jerk given that intra frames are added to arrive at the “imposed” value
You can type any value into the dialog box for FPS by highlighting the text.
Omfg didn’t check that possibility !
So will try x2 and x3 and let my difuser CPU (Creality or X1 in my case) interpolate itself to native abilities.
Thank you :slight_smile:
EDIT : Unfortunately, it doesn’t work
Whatever I type if not in the selection it remains rejected.
