Looks like frame interpolation models realy need improvement.
Bugs:
Object geometry change
Blur
Wrong movement sometimes (like frame 1 2 3 4 5 3 6 7). Check OriginalDedup_apo8 folder. Its even more bad than duplicate frames because duplicate frame goes not right after its copy.
Its when images source used. 2x interpolation. Maybe this bug only in image source.
Blocky interpolation
And compare to RIFE. RIFE can do 16 frames from 2! And all of them will be correct (only around fast moving object there will be not correct interpolation (but not so visible).
Maybe RIFE is good at cartoons. From my testing though, itās not nearly as good at normal videos as Apollo.
But yeah, the Duplicate Frames āReplaceā check has never worked as expected. The duplicate frames are taken into account when calculating motion.
I think a non-motion-blurred interpolation model for cartoons would be something widely useful for several users.
Well Apollo is good at ānormalā videos (where movement is not fast). Where it fast blur occures and object proportions change. Its just in cartoons there is always fast movement from frame to frame.
Are you sure that duplicate frames are taken into account for calculating movement change? Its surely a bug then. First they need to be removed and then processed.
By the way - example here OriginalDedup_apo8 is done on source deduped by hand (so source does not contain dups and replace duplicate disabled in apollo). And result have wrong sequence of frames.
