Frame Interpolation 8x, drop frames
Hi!
My input footage is Prores 4444 16 bit, 24 fps.
I’m trying to go to 8x slow-motion and It makes a duplicate frame every frame, so I have to speed up the video twice as fast later on, in order to fix this.
Hello,
Could I take a look at a clip of this footage to run some test exports?
You can securely submit your file(s) to our Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Submit to Dropbox
