FPS setting Dione DV Topaz Video 7.1.5 and 1.7.1
Hello,
fist my english is not so good please excuse.
I use the Video 7.1.5 as testversion and I bought new the 1.7.1 Version.
I have DV avi and want it deinterlaced to 50 FPS. With the 7.1.5 i can change from 25 to 50, see 715.png It is below the frame interpolation. For that i must not activate the frame interpolation.
It works I see it in the export text and with the App Media tool information.
When I now want to do this in 1.7.1, see pictures 171 A and 171 B.png, I can only do that when frame interpolation is activated. When I activated thsi i must chose a Model like Apollo. When I not activate this the FPS is 25.
Is this normal now?
Dione DV should do the work to 50FPS automatic or not?
For help i would be thankful.
Best regards
Klaus
Working on getting you answers and will send them to the support ticket you opened with the team, Klaus.
I’ve had a look into this and it appears the work-arounds are either to use the CLI or to create a preset based on Dione DV. As that defaults to 1x deinterlace, you then edit your preset file to make it 2x deinterlace:
I can’t remember offhand where the user presets are stored on Windows, but on Mac they are inside the application itself:
e.g.
Applications/Topaz Video.app/Contents/Resources/presets/Andy DDV 2x.json
Once you find your preset file, open it with any text editor. Then in the “output” section, add the following at the end, before the close curly bracket:
“outputFps”: “2x”
Make sure that Topaz Video is closed when / if you’re doing this.
That worked for me and the resulting FFmpeg command correctly used bwdif=mode=1 for 2x deinterlace. For 1x deinterlace it’s bwdif=mode=0
Regards
Andy
Sorry, Klaus, I should have to replied to you rather than Kyle.
Thanks fpr help I will test it.
At the mean time i test VCG Deinterlacer which work too.
But I mean that it look from the colours and brithness not so good like Dione DV
update
i can not find my present on the computer. I have Windows 11.
update
i found it now, there are many folders where topaz is installed on windows.
