I was working on an image with Focal Blur and found the following:
When you use the circular you get a superoimposition of a circle which you can expand and rotate.
With the tilt shift there is no such guideline which I believe would be very useful and make the adjustment much quicker
AiDon
(AIDon)
August 31, 2017, 3:30am
Yes I agree, something like the overlay of the gradient mask and also offering the Angle in degrees (0-180) … or simply implementing it as two gradient masks?
The degrees would be awesome and the two gradient mask idea is also a very good one.
pjglad
August 31, 2017, 10:12am
4
I submitted a feature request for guidelines about 10 days ago.
