Flow Chart for processing
Hi Newbie Question. Is there a flow chart for using Topaz software, or suggested sequence for processing? EG Denoise, Sharpen, AI Etc
Many Thanks
Kevin
Hi Kevin, here’s e helpful YouTube video from TopazLabs, explaining how use all three applications DeNoise AI, Sharpen AI and GigPixel AI, in conjunction with Lightroom Classic to edit a photograph.
https://youtu.be/80aasB7Oaw8
I’ve also included the accompanying article to the video
https://www.topazlabs.com/learn/wildlife-photo-editing-improvements-made-easy-with-denoise-ai-sharpen-ai-and-gigapixel-ai
Many Thanks Andrew, It’ll be good to have a road map to processing. Thank you for taking the time to post, its much appreciated.
Kind Regards
Kevin
hello again Kevin, here’s an article from the Topaz Help Center
When To Use DeNoise AI, Sharpen AI, and Gigapixel AI
https://support.topazlabs.com/article/45-when-to-use-denoise-ai-sharpen-ai-and-gigapixel-ai#gigapixel
I’m also including the Link for the Help Center https://support.topazlabs.com/
hope this helps
