I had numerous problems with low FPS (Max. 2 fps) and in several conversions to 1080p and 4K my PC would shut down during the procedure reaching temperatures above 80ºC.
After replacing my old card (AMD RX 590) with a newer one (RX 6700 XT) I still had low FPS problems (2 fps). I found a thread here that said to delete the registry keys inside the Computer\HKEY_CURRENT_USER\SOFTWARE\Topaz Labs LLC folder
Well I did that and miraculously from 2 fps my conversions went to 11 fps with the video card not even reaching 60ºC anymore.
The problem is that when deleting the registry keys folder I tried to use AI Iris and the output video was only rendered at the beginning, getting a black screen afterwards. I was able to convert the full video using Proteus, but when importing the video and trying to export it as mp4, it says
"Error: Audio stream #2 contains ‘pcm_s16be’ audio wich can’t be used with ‘.mp4’ container. Select an alternate Container to copy audio, or change Audio Mode to ‘Convert’ (this may cause loss in audio quality). So I used .mkv and everything works fine.
Well I think deleting the registry keys infinitely improved my fps, cooled my video card by over 20ºC and I’m not experiencing PC shutdowns anymore. However it broke other functionality, anyway if some developer can help me and tell me what I can and can’t delete from the registry keys… I think it would be the perfect solution to many people’s problem.
DxDiag.txt (96.6 KB)
