Recover faces stops just below chin leaving the remainder of a neck looking terrible. Maybe update to include same or similar skin below chin in the recovery. Fingers are a mess almost always. They seem to be turned into claws, perhaps software identifies them as talons?
Just wanted to second this comment. I was testing a few different AI image tools, and Gigapixel worked very well in most scenarios, but hands/fingers typically looked extremely distorted and creepy.
We’re working on decreasing the sharpness of the boundary so the face blends with the rest of the image better. The current model was built to only work on the face and part of the neck.
For now, I would recommend decreasing the face recovery strength. Also try experimenting with the Remove Noise model strengths if that is being used.
Thanks for your patience as we continue to improve our models!
