When using auto Sharpen Subject and then manually selecting any slider setting for Remove Noise, the final rendering leaves a black masking over the subject or fails to render the subject.
Steps to reproduce issue:
Step 1: Auto Sharpen subject
Step 2: Enable Removing Noise - any slider amount
Step 3: Select any of the viewing options for after processing the image
Please visit this page, select your operating system (Windows) and click “Find Your System Profile”. Send me the system profile so I can check your system specs. Topaz Photo AI System Requirements
Was this happening in previous versions of Topaz Photo AI?
