Film restoration settings suggestions using TVAI 5.04
I have some regular 8mm movies taken in the 1960’s. They have the usual artifacts such as soft focus, scratches, and some jitter due to the shaky photographer.
The scans are in DVD format. I have converted the files to MKV files.
I would appreciate some suggestions on TAV! 5 settings. I am going to try up scaling to HD.
Bob W
8mm topics from search
Thank you, Mike for the research. I tried to read all the way through all the associated posts and pick out the relevant points. I will have to experiment with the suggestions.
Thanks again,
Bob W
