Can we please have an option to FILL a whole image with a mask. Sometimes using Landscape in the Refine menu gives the right result but occasionally, especially with plates of food, it will detect only one leaf as the subject and using Landscape does not have any significant effect so one has to manually fill the screen with overlay which both time consuming and tedious.
You can always turn off the Auto Mask from within the Preference Menu, you can also turn off the Mask from the Subject Detection option just click on refine and select none or from the Sharpen Menu and deselect Subject Detection.
by selecting any of those options Photo AI will then process the whole image
You can find all the information you need about Photo AI, from the support page found at the bottom of any of the TopazLabs pages, here’s the link
https://docs.topazlabs.com/#contact-us
Hope this answers your question
