In 3.5.2 there is a graphical ‘card’ (containing the current filename) that appears above the “input” pane where the open files are located, and occasionally it appears and won’t go away. This blocks the timeline and other controls on the left side of the screen. I feel like it was meant to be a mouse-over that should disappear but it doesn’t unless you exit and relaunch the app.
System Profile:
Mac Pro, 2019
Processor: 3.2 GHz 16-Core Intel Xeon W
Graphics: AMD Radeon Pro Vega II 32 GB
Memory: 192 GB 2933 MHz DDR4
PCI cards: 8 PCI Card Slots
macOS 13.6 (22G120)
