Feature Request | Out-Of-Gamut Color Correction Tool
I shoot & process in Adobe RGB, but need to deliver in sRGB and CMYK. Correcting out-of-gamut is tedious and time consuming in Photoshop or Lightroom, and it would be great if Photo AI could automatically detect out-of-gamut colors, apply adjustments to bring them back into range while preserving vibrancy.
Hi Kevin.
Are you aware you can add a vote yourself
I’m afraid I won’t be voting myself as I don’t see this as something really suited for an image enhancement application like Photo AI
An image editor on the other hand like Photoshop would be better suited for this type of task
Thanks for the idea and suggestion! Make sure that you do not forget to vote for your idea :slight_smile:
