While using the “Remove” feature of the software, I will sometimes click ‘reset’ instead of ‘remove’ and lose all the work I put into the removal process. Is it possible to have an option to confirm that you want to reset when that button is clicked?
My second request is that sometimes, when using the remove feature, it puts something in place that is worse than what you were trying to remove initially. It would be nice if there were an undo feature that only undoes the last change.
Thanks!
