Feature Improvement | Metadata Between Topaz Photo & Gigapixel
I am using the studio versions of photo and gigapixel. My comments are suggestion not a complaint.
It would be helpful to have a more unified GUI. Metadata can be stripped when using gigapixel, have not seen this when using photo. Unsure what the credit thing in the upper right hand corner. Does not seem to change when using the cloud for render. Not sure what to do with the latest email regarding bonus credits? Tried it but nothing changed.
Hi Jim.
Can’t answer the Metadata question however, as for the Credits issue it’s simply indicating how many Cloud Credits you have left and is shown across all applications and the reason they don’t countdown within either Topaz Photo or Topaz Gigapixel is because, we now get free unlimited Cloud Rendering for images and you only use Cloud Credits for Rendering Video.
Hope this helps
Hello,
Could you share a more detailed explanation of your suggestion and how it affects your workflow?
Providing screen captures or mockups can be helpful for us to better understand your suggestion.
In the studio release of Topaz Gigapixel there shouldn’t be any cloud credit indicators since cloud render is unlimited and no longer uses credits.
Thanks for the additional feedback and request :folded_hands:
My point regarding metadata was the removal of gps coordinates, when using the studio ver. of gigapixel, This is not seen when using the studio ver. of photo. The gui comment was related to the difference in the opening screen. Adding the preview screen in gigapixel to the photo app open screen. Adding consistency regarding the location of the preview buttons between the two apps. (full screen half and half).
