Feature Improvement | Face Swap
It would be helpful if the AI ​​could restore faces at family photos by training the software using existing fotos with higher resolution with this specific faces.
It should be possible to swap faces on family photos with better quality photos so one can redefine a face too blurry for recovery. I just tried it with an online tool with amazing results.
A combination of recover, face swapping and redefining
Thanks for the idea and suggestion! Make sure that you do not forget to vote for your idea :slight_smile:
Oo
ps, i did it again
FaceFusion is software that I use. It can do both photos and movies. It even has an option to colorize black and white films to color and it is free.
You can install it on your computer or run it in Pinokio
FaceFusion and ComfyUI are good softwares for face swapping. And I also use FaceMe, Bestface swap app to improve old photos.
I use PIXLR. But it would be great when topaz could integrate something like this in their softwares.
The used face for swapping is from a photo taken at the same occasion with higher resolution.
