Feature Improvement | Face Recovery Detection Tolerance Sliders
Face detection does a good job of identifying faces in an image, but the down side is that it’s a black box on how it makes its autopilot selections. For example, even if i say select “only subjects” it selects in faces around a subject even when they are clearly farther or closer in the field of view, creating a ton of friction when working with a large batch of images because i have to go through hundreds of photos and deselect faces that are not the subject. (like a soccer player on a field and it’s selecting parents and other players behind them that are clearly not part of the subject). This stems from the subject masking tool being very poor quality.
I shoot sports with f/2.8 or lower and i don’t want face detection to select anything but my subject, which may be slightly soft in focus (or usually there’s a heat dissipation on a field so things get soft).
(the people int he background are clearly at a different focal level)
(the masking tools are severely lacking in quality and way behind other tools)
What I propose is a slider that has a tolerance of how soft a face as to be to be auto-selected. Lower numbers means only select subject faces that are just slightly out of focus and the higher the number the more out of focus a face may be.
This could replace the current, fairly useless dropdown choices.
OR <<<<
A patchwork until you fix your masking tools, what if while a user was HOLDING DOWN the M key, they could deselect or select faces without having to go to another mode? That would be a good bandaid until other tools get better.
