When working with raw images they are large and thats why it takes time render hole image when check different layer modes effect…
Suggestion is there way to use small preview window like this navigator on 2.08 to show what ex layer mode change could look like – perhaps “Apply button to that” like in effect and Looks.
When working with small images this not so bad must there plenty of users which work larger originals
I want the image bar again too, with the APPLY button, it let’s me create different looks and compare them!
Yes, its one of the major drawbacks to TS2 and they need to add the image layers as well. In TS1 you could have any adjustment work on the original image or the results of previous adjustments but this is not available in TS2. Overall I still like TS1 much better.
