Facial moles
Steps to reproduce issue:
  1. Step 1 open facial image with soft very pale moles in skin
  2. Step 2 allow auto to tell you what can be done
  3. Step 3 sharpen is offered…use it… creates very dark enlarged holes in skin. This can require a lot of editing time to remove
  1. The original image file.
  2. The processed image.
Dropbox File Request
