Unfortunately I have to report again, that the “Face Recovery” option will get disabled during a running batch for any reasons. Mostly right after the first, at the latest with the third image of the image staple. That means that I have to stay on my PC and need to handle manually image by image. That is what I can’t deal with, folks. It is an old bug here and it is still here. Nothing helped, not even a complete new installation from the bottom, therefore the operation system. And read the comments, folks, I am not allone with this!
To the bug mentioned above a further one has to be added, namely the “model settings” option. Usually this option should has to be activated permanently here, but it also gets deactivated automatically right after an image gets closed after a work process. Totaly independing whether I worked on one photo or more, you have to activate it manually again and again.
For the reason that is issue is still not fixed, furthermore it has become even more, because there is a similar problem added with the “Model Settings” option, which has to be activated
Up to that get not fixed and the software runs stable, Gigapixel is a worthless toy and I will not spend any further money for that! This way, folks, your software os not able to beused in a business but only for people who need it for funf time by time! Is that your way? Than let me know, so I happily will remove it and never bother you again!
