Hi, I’m new to Topaz AI products, so I may be missing something. It seems that the only option for Face Recovery is the size and spot the software determines. Many times it’s just fine. However, often it doesn’t select the enough, such as head or facial hair. The results end up with most of the face being sharp and beautiful, but then the bottom or top is too blury. This makes it very evident it was edited and not a natural photo. Best would be if we can adjust and move the focus square in whichever way is needed.
Hi.
This is expected behaviour for the Recover Faces Enhancement, it’s face detection, not head detection and is the same for other companies face detection software ON1, Adobe and so on.
Having said that, you can change this a little by telling Photo AI to also add Hair and Neck by selecting this option within the Preference Menu.
Here’s a link for the Recover Faces Guide
Hope this helps
Thank you for the response.
I just found the option in the preferences, however, it was on already. So I kinda feel like we can do better. Perhaps by having the option to expand the selected area.
